I believe there is another clip attached the throw out bearing on the input shaft, clipped to the top of the fork. I don't remember correctly but you should be able to pull the fork out and it'll be released from the top clip. when you re-install make sure you the top part of the fork is attached to the clip then attach the clutch fork to the pivot ball.
